Status Future consideration
Created by Nina NICHOLLS
Created on Jul 12, 2021
allow selective movement event move lot without specify material using material class contraint
https://schneiderampla.atlassian.net/browse/CE-2234[System Info]
Ampla Versions: 8.0 MR2
Operating System:Windows 2012 Server R2
[Raised by]
Customer Company: Talison
Customer Contact: vy.nguyen@aveva.com
SR Reference: 960052444
[Problem Summary]
Talison requires user to create 'bag movemet' from workcenter to another workcenter. They want to use 'selective' behavior to overwrite FIFO/LIFO sequence mixed with normal batch movement. In reality user will scan a batch code to decide what lot will be moved out seletively. When they create selective movement, end user needs to specifiy 'material' on source and destination, which is extra step, as batch scan does not have material information on the ground, they need external data query to get material, which is still extra step. Talison hope to have fully automatic lot scan workflow. So the requirement is:
allow selective movement event move lot without specify materia, all material specification is based on existing material class contraint.
[Workaround]
n/a
[What is the impact to Customer/s]
extra workflow needs to be created.
[how to reproduce]
1. import project xml
2. create 3 inputs with x, y, z material with same lotgroup
3. move all lotgroup using A2A movement, user does not need to specify lot, material.
4. undo step3. delete it
5. overwrite lot behavior to selective, specify a lot in the middle. Ampla ask to give destination material, you still need to give source material even if it does not ask for it.
  • Admin
    Nina NICHOLLS
    Oct 17, 2023
    This is a future consideration when we look at Inventory in the cloud.
