Portfolio area Application Server
Products GR
Created by Florent Michelfelder
Created on Oct 18, 2024
Improve Gr Access toolkit
Improve GrAccess toolki to support :
  • Edit Security
  • Edit ViewApp (Navigation, security features..)
  • Allow to export as xml or text file Layout, screen profil, ViewApps, namespaces the same way as Industrial graphics
  • Export Template definition (text file)
  • Export / edit / import Namespaces
    Oct 21, 2024
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
  • David Anderson
    Mar 27, 2026
    I'll add, specifically, that GRAccess should have the ability to set IO assignments and overrides like the IDE's IO Devices and IO Mapping panels.
    More generally, make it so GRAccess can do anything the IDE can do.
    We're seeing an increase in customers that want to automate galaxy operations, and GRAccess has limits.
