Portfolio area Application Server & OMI
Created by Mathieu VANTARD
Created on Oct 28, 2024
Color animation through element properties
You can change an element x, y, width... by accessing its properties through script.
Could be helpful to get access to other properties for FillColor, LineColor, ElementStyle,...
Attribute could be set by hexacolor.
The interest would be to extend ElementStyles concept without consumming UserDefined.
E.g. when you animate a entity status that comes from AVEVA MES, you couldn't use/link the color used in the MES configuration. You can fix the list of available colors vs statuses but if a user create a new color in the MES side it will destroy all your efforts. MES returns an HEXA color.
I've many other use cases if needed ;-)
    Oct 28, 2024
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
