Portfolio area Application Server
Created by Eivind Fotland
Created on Nov 20, 2024
Graphic Connectors not working when exceeding 1280 pixels
Angled connector lines do not maintain their horizontal and vertical orientation with 90-degree angles, when placed in a symbol whose dimensions exceed 1280 by 1280 pixels. This is known to Aveva, but no solution on this so far!
When using Archestra Graphics within OMI, you should NOT be limited to a certain symbol resolution/size. But this is the case now. Instead of using connectors we are forced to use several lines adding animation to 4-5 lines instead of adding 1 animation on 1 connector, which in turn will lead to lower loading performance in runtime.
    Nov 24, 2024
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
  • Jakob Drescher
    Nov 25, 2024
    With the resolution independent graphics and prices going down on large monitors, we are seeing more solutions including large monitors with high resolution.
