Portfolio area Application Server
Products IDE
Created by Andrew Drane
Created on Sep 23, 2025
Update default naming method of objects when creating new instances
Currently when creating a new instance of an object with child objects, the default naming system makes for a lot of extra work. When instantiating an object, allow the user to put in its name instead of naming it "Object_001" with child "Child001,Child002,child002" etc. This leads to hundreds of objects with useless childrens names that have a lot of potential to cause issues when importing from development environments to production environments. IE: "Child326" into a prod environment that already has "Child326" and now I have to go rename EVERY child object before I export it.
Allow the user to put in a name for the object when creating it, then using that as a prefix in children. So its more similar to the contained names we create when defining the object templates.
    Sep 27, 2025
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
