Portfolio area Application Server
Products Other
Created on Jul 28, 2026
A method or event for AOT objects to detect when the hosting AppEngine changes its redundancy role (Active/Standby)
In traditional redundant AppEngine setups, AOT objects could use the RuntimeSetScanState event to detect when an engine became active and then execute role-specific logic.
With Warm Redundancy, both AppEngines remain OnScan, so RuntimeSetScanState is never triggered during Active/Standby role changes. As a result, applications must periodically check the engine role, which adds unnecessary overhead.
A dedicated event to notify AOT objects when the hosting AppEngine changes role (Active ↔ Standby) would be very useful. It would allow role-dependent logic to run only when a role transition occurs, eliminating the need for cyclic polling and improving application performance.
    Aug 16, 2026
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
