OSM Improvement suggestions - Check box inside the IP I search field
"If you are going to search for an IP or an IL, you have several choices in the right-hand corner to specify the search. Among them, you have the option to select specific statuses you want to search for. Here there should be a common check box at the top where you can tick off all/remove all with the press of a key. It is very cumbersome if you are to search for an IL but do not know what status it has. As of now, it is predefined for a mechanical IL to tick the status "NEW" but since you do not know status, you have to search all statuses. Which means that you have to check 28 extra boxes to be able to get all statuses. Comment from Per Sunde: Should be able to select all/none with own buttons. Version 11.2 will improve this somewhat because filter stored per user."
