OSM Improvement proposal - Printing of IP and IL
"Previously, you had the option to stand in IP and press "print" and check that you wanted to print the IL list with the isolation points and P&ID in addition. This option has now been removed and to print the IP with associated documents you have to press for an eternity to get everything. Why was this option removed? Up against an audit stop with 50 IPs, it would be very time-saving if you could get back the option to print IPs. But also in everyday life when a job is to be carried out. It should be enough to press print out the check mark of the attachments and ILs with the P&ID you want. AVEVA IMS number 1789398"
