Tollerance factor value change in case the flow meter measured value is out of pre-defined range
Flow meter's accuracy changes when measure value is out of range. Hence, there should be a mechanism to support this feature with-in the application.
This can be enabled with logical conditional statements for tolerance value settings. Instead of numerical value configuration , this can be enabled with equation editor so that user can configure the conditional statements to handle the change of tolerance values.
