Status In Roadmap
Portfolio area Historian & Client
Products Data Acquisition
Created by Marcell Marjee
Created on Oct 15, 2025
[PlantSCADA] Better support for tag config changes on PlantSCADA end
4.3 Changes to Plant SCADA configuration
Where there are changes from the PlantSCADA side, a restart of the connector is required however there are many cases of where the users forget to do this. A reminder message may help.
Looks like this is done by choice. The connector currently needs very little configuration to log SCADA data to Historian. When the Connector service is started or recovered from disconnection, it will automatically discover tags from SCADA and add/modify the corresponding Historian tags as required. The flip side is that it removes customisation possibility from the users.
In terms of detecting whether the tag configuration are up-to-date, it is possible for the Connector to periodically call ServerGetProperty() Cicode function via CTAPI to compare the date time of the RDB file loaded on the SCADA server against what is used by the Connector.
