ADO Work Item #4695422 — Historian CORS allowlist is not working as expected
https://dev.azure.com/AVEVA-VSTS/_workitems/edit/4695422
RESOLUTION
This issue is working as designed, and to support a desktop-style application to use this interface requires changes to the middleware between the request gateway and the API endpoint, which can only be considered for a major release, is therefore considered an enhancement which needs to therefore be prioritised against all other requests.
The proposed enhancement would entail:
1. Introduced dedicated early OWIN middleware for CORS handling.
2. Loaded allowed origins from CorsSetting.json.
3. Validated incoming Origin values against the configured allowlist.
4. Applied the required CORS headers for valid cross-origin and preflight requests.
5. Prevented downstream services from overwriting gateway CORS headers.
6. Reapplied final CORS headers before sending the response.
7. Verified that configured origins now work correctly while normal non-CORS OPTIONS requests continue through the pipeline.
DESCRIPTION
I have reproduced the issue with simple cors allow list
<!DOCTYPE html>
<html>
<head>
<title>Call Java REST API</title>
</head>
<body>
<h2>Get User Data</h2>
<button onclick="callApi()">Fetch Data</button>
<pre id="output"></pre>
<script>
function callApi() {
const username = '***********';
const password = '**************';
// Encode credentials to Base64
const encodedCredentials = btoa(`${username}:${password}`);
fetch('http://10.0.0.4:32569/historian/v2', {
method: 'GET',
headers: {
'Authorization': `Basic ${encodedCredentials}`,
'Content-Type': 'application/json'
.then(response => {
if (!response.ok) throw new Error('Network response was not ok');
return response.json();
.then(data => console.log(data))
.catch(error => console.error('Error:', error));
</script>
</body>
</html>
The logger shows it matches the CORS policy
SetCORSPolicy:Request.Headers.Get:http://10.0.0.5
AllowedUrls:http://10.0.0.5,http://CLIENT,http://CLIENT:80,http://10.0.0.5:80,http://10.0.0.5/Dashboard,http://CLIENT/Dashboard
Found:True
ContextRequestUri: http://10.0.0.4:32569/historian/v2
/favicon.ico:1 Failed to load resource: the server responded with a status of 404 (Not Found)
home.htm:1 Access to fetch at 'http://10.0.0.4:32569/historian/v2' from origin 'http://10.0.0.5' has been blocked by CORS policy: Request header field content-type is not allowed by Access-Control-Allow-Headers in preflight response.
10.0.0.4:32569/historian/v2:1 Failed to load resource: net::ERR_FAILED
home.htm:31 Error: TypeError: Failed to fetch
at callApi (home.htm:19:1)
at HTMLButtonElement.onclick (home.htm:8:29)
(anonymous) @ home.htm:31
home.htm:19 GET http://10.0.0.4:32569/historian/v2 net::ERR_FAILED
callApi @ home.htm:19
onclick @ home.htm:8
Promise.catch
callApi @ home.htm:31
STEPS TO REPRODUCE
Just write a simple REST API call from two nodes.
Promise.catch
