Portfolio area Application Server
Created on Jan 16, 2025
OS-Configuration Utility needs an option to not overwrite existing Firewall rules during upgrades.
We are using System Platform 2023
After our normal installation and hardening, we have 22 firewall rules on the system.
After installing the SP, (with OS-Configuration Utility) we suddenly have 245 rules.
See attachment for details.
Requirement:
-When installing a service patch, an update must not disable or modify a hardened system, such as the Windows firewall in this case.
1) Parameter transfer for installation is sufficient for us. So something like “OS-Configuration-Utility.exe -NoWinFirewallChange”.
Keyword is Silent Installation Parameter.
2) Selection/deselection via GUI using “Customize Installation” is also ok for us as an option, but point 1) is clearly preferred.
    Jan 26, 2025
    Your idea has been reviewed and the title has been edited to more accurately state an idea or requirement instead of a problem or defficientcy and to remove any perceived sensitive or identifying information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
  • Admin
    Rickard Norin
    Jan 24, 2025
    I'm reassigning this to Application Server since it's mostly relevant to System Platform.
    The stand-alone HMI will move away from using the OS Configuration Utility.
