Status Planned
Portfolio area InTouch HMI
Created by Mathieu VANTARD
Created on Feb 13, 2026
UDT export format/options
Hi,
JSon export format is really flexible but customer/SI are complaining about. Here are the options that could bring it close to perfect 😉
  1. Could you add an option to export/import UDT instances in csv format (without their members). It would be helpfull to do batch imports.
  2. could you add an option to export all properties even if they are not been set ? Default values aren't embeded in JSon. This prevent user customizing then in the file or ask them to copy past. Not really convinient.
  3. Could you provide an external tool or a document on how to modify JSon file in a raw format ?
Thanks
    Mar 13, 2026
    Thank you for submitting this feedback, which is well in line with our intentions for the UDTs. We are considering tabular text format as an option for both import/export but also copy/past to/from the clipboard so that one may go quickly between WindowMaker and Excel, even accross RDP sessions.
    We will take into consideration the details of your feedback especially that of default values.
