Make LDAP configrable at the point of installation
AD calls occurs over the LDAP protocol. When an object (user or group) resides in another domain, the domain controller sends a referral back. This means that it sends a pointer and the LDAP client (ISM) is required to contact the referred server to get the object required.
I made a small LDAP client in Powershell (.NET class System.DirectoryServices.DirectorySearcher) to mimic how I believe ISM handles LDAP communication. When I turn off ReferralChasing, I see identical behaviour as Jacobs is having.
When I enable ReferralChasing, I can get at the users and groups in other domains.
My current suspicion is that ISM needs to updated with the following:
If we implement this in a fix release, I assume Jacbos would only need to update web.config to point at jacobs.com instead of europe.jacobs.com after installing the fix to resolve the cross-domain issue.
Default value for ReferralChasing is ‘External’ in .NET System.DirectoryServices.DirectorySearcher class which would lead to the issues we’re seeing at Jacbos.
If we can get a test release with ReferralChasingOption = All and PageSizeturned off, I have a multi-AD environment with ISM that we can use to test.
This should be defaulted to "All"
