Created by Andy Davidson
Created on Jan 28, 2022
Support extensions in ISM with > 1024 characters
Can we add an item onto the backlog to support extensions in ISM with > 1024 characters.
Since we are using ISM for recording certain configuration, an example situation is a JSON template which may easily be larger than this, which will make a limitation for what we can achieve.
It could work that we add some other concept to ISM that then gets referenced from an extension.
I am assuming there are no other options already available as e.g. enumeration descriptions have similar behaviour.
1 MERGED
Increase the number of Characters in various Properties
Merged
https://dev.azure.com/AVEVA-VSTS/Information%20Management/_workitems/edit/1725333 States: Url: https://dev.azure.com/AVEVA-VSTS/Issue Management System/_workitems/edit/1650623 Created On: 25/11/2021 12:29:30 Product Area: Issue Management System\A...
Geoffrey Coad over 4 years ago in Information Standards Manager
