Portfolio area Measurement Advisor
Products Telemetry
Created by Andrew Potkins
Created on Mar 12, 2026
Alternate calculation methods for atmospheric pressure
Requesting support for multiple calculation methods for atmospheric pressure. The following calculation method is requested to be added as a supported method of calculating atmospheric pressure:
"Provide the ability to calculate or select the atmospheric pressure at a meter location based the elevation(meters above sea level) at the meter location. The atmospheric pressure must be calculated using the following equation or determined from a lookup table. Atmospheric Pressure (kPa) = 101.62 - (0.0113 * m) where m is equal to the elevation above sea level in meters."
Examples:
Elevation (m)
Atmos Press. (kPa)
0
101.620
100
100.490
Current application generates the following atmospheric pressures
0 m elevation, 101.572 kPa, 100 m elevation 100.369 kPa
  • Admin
    Mike Demcoe
    May 6, 2026
    Where does this formula come from?
