Allow the use of negatives at the start of Evaluated field expressions
https://dev.azure.com/AVEVA-VSTS/Issue%20Management%20System/_workitems/edit/1583351
Customer creates an Evaluated Field with Evaluation expression starting with "minus" sign, for example
-[Source1].
The project validates successfully but the reporting point does not log values in runtime.
The exception is thrown "Exception: System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: Operator: NEG"
Customer is confused because you can use "minus Variable" expression in HistoricalFieldExpression but this does not work in Evaluated Field.
[Workaround]
Use "Zero minus" instead of just "minus" in Evaluation Expression:
use 0-[Source1] instead of -[Source1]
[What is the impact to Customer/s]
As per the customer:
"Workaround solve the issue, but some junior Ampla developer or customer’s administrator can make a lot of errors with evaluated production fields."
For more info on the primary case, please visit:
https://gcsservicecloudutils.azurewebsites.net/casedetails?casenumber=960118801
    • Admin
      Nina NICHOLLS
      Oct 10, 2023
      Will not implement as low priority and there are multiple easy workarounds available for this issue.
