Status Future consideration
Created by Nina NICHOLLS
Created on Feb 1, 2023
Make the diagnostic webservice public
[Problem Summary]
Customer has been using the GetActiveSessions method in the Diagnostics web service through HTTP in 6.5. Most Ampla web service end points are available through both HTTP and NET.TCP. However, since their upgrade to 8.1, they have not been able to use it anymore because only the NET.TCP end point is available for Diagnostics web service and that the Diagnostics web service through NET.TCP does not seem to be configured properly for actual use
[Reproduced in-house (Sydney GSC)]
YES
[Steps to Reproduce]
Use Visual studio, add WCF Web Service Reference:
Only the net.tcp end point is available as it can be seen in the Citect.Ampla.ServiceModel.Services.config file and it's not usable in Ampla's default configuration.
<add baseAddress="net.tcp://localhost/Ampla/Diagnostics/2007/07/Tcp" />
[Workaround]
none
[What is the impact to Customer/s]
Customer cannot use the GetActiveSessions method in the Diagnostics web service for their internal audit purpose
For more info on the primary case, please visit:
https://gcsservicecloudutils.azurewebsites.net/casedetails?casenumber=960234850
