Status Future consideration
Portfolio area Predictive Analytics
Created by Naveen Bandu
Created on Jul 12, 2023
PA Web Fault Tree Visualization Customization
Current Fault Tree Visualization structure is showing Project > Fault condition > Fault Diagnostics > Fault Signature. It would be good if further setup UDP with multiple layer hierarchy, for example: Bearing Fault as parent UDP with two child UDP 1, Radial bearing fault, 2, Thrust bearing fault.
Why is it useful: customer will be able to build up comprehensive, in-depth fault tree and visualize it.
What is the befit if it is enhanced: It will be easy to find out the faults with well established fault tree.
How should it work: enable UDP with parent – child hierarchy so that each UDP could have its category or parent property.
