OPCUA Variable Import limited to 79 characters
When you import Variable Tags from an OPCUA Server the tag names are truncated to 79 characters, this is sometime not enough. Duplicate tagnames are not allowed. You have to manually adjust all the names. For instance when you connect to a Plant SCADA OPCUA Server and import the variable tags the first part is always:
Objects\BrowseProvider\Cluster1\
Would be better to skip the Objects\BrowseProvider\ part and put Cluster1 into the cluster field, but this is maybe rather specific for the Plant SCADA OPC UA Server.
Idea business value
Would make it a lot easier to import variable tags from an OPC UA Server
      Nov 13, 2023
      Same problem detected when connecting to a codesys OPC UA server. Variable names are truncated resulting in the inability to obtain unique names. The only solution is to manually rename the variables, however losing the possibility of automatically updating the database. This update should have top priority.
    • +13
