Status Implemented
Portfolio area Plant SCADA
Created on Oct 20, 2023
Make kernel available when running as a service
The kernel is a major PlantSCADA debug tool. It is not available when running as a service. Accessing the kernel required a major reconfiguration of a project in order to perform debugging. Make the kernel available when running as a service.
Idea business value
In order to access kernel of a system that normally runs as a service requires a major reconfiguration of the system and has a significant impact on the customer's operation while debugging is being performed. Having the kernel when running as a service greatly reduces the work required to perform debugging of a system that normally runs as a service.
Idea priority 5 – Critical to my company
    Oct 24, 2023
    • Kernel now works when running as a service in Plant SCADA 2023 R2
      • ​​​Users can open the kernel of any process via Runtime Manager and will be prompted for credentials to login.
      • “Kernel user” has been deprecated, A new “Kernel Access” property has been added to the Role definition to control access.
  • +4
