Status In Development
Portfolio area Plant SCADA
Created on Feb 23, 2026
Update versions active x controls - Process Analyst , Database Exchange or add new ones.
Libraries of Active X haven't been updated in a long time, could use refreshing controls with the new times ;)
Everything looks like from 20 years ago.
Clients wants New Bargraphs, Gauges, Datapickers for Reports, Textbox, Tables, etc.
Are there any plans for this updates ?
Idea business value
Nothing has changed with these indicators for 20 years and they have their limitations.
Idea priority 5 – Critical to my company
  • Admin
    Nathan Slider
    Apr 1, 2026
    The AVEVA HIstorian Client Web control supports ALOT of these modern bargraphs, and data analysis views, plus allows ad hoc math functions to be used on the tags at runtime to perform on the fly calculations, of which now that the commercial components of Historian are now included with the product, the next step in the roadmap is to enable SSO and easy passing of Tags to the Historian Control which can be embedded into a Plant SCADA Standard graphic. AVEVA Reports is a another tool that provides data pickers to help easily build Reports and views, again included with Plant SCADA that will help deliver some of this value back into the Standard Graphics views.
    Mar 30, 2026
    Also agree and fix it so that it is possible to have MQTT in plant scada as a driver, and a parallel transition from cicode to python programming
  • Inge Kronstad
    Mar 4, 2026
    100% agree! AVEVA needs to step up if AVEVA Plant SCADA is to remain an attractive platform.
  • +12
