Portfolio area Plant SCADA
Products Equipment
Created on Feb 17, 2023
Unify automatic generation of Configuration Parameters in Plant SCADA Studio 2023 and Equipment Editor
Currently when adding new Equipment through Equipment Editor, all relevant Configuration Parameters will be generated automatically and are available in Plant SCADA Studio 2023.
However if you add a new Equipment in Plant SCADA Studio and run "Update Equipment", the Configuration Parameters will not be automatically generated. You have to know the exact name of the parameter and add them manually.
I want:
If you have added new equipment in Plant SCADA Studio and run "Update Equipment"(or a button for updating configuration Parameter), the Update will first iterate through all defined equipments. If the equipment have a type with a configuration parameter, and the configuration parameter does not exist, the configuration parameters for the selected type will be added with default vaule.
When the configuration Parameters have been generated, the update equipment process with its normal routine.
Idea business value
Creating new equipment in Plant SCADA Studio and Equipment Editor yields different results. This is inconsistent and a poor design for system integrators using this tool.
    Jun 2, 2023
    Its really hard, to work with the new "parameter-structure" in PlantStudio.
    May a list of Parametters on the left-site-panel will help
  • +21
