Status Submitted
Products Process Design
Created by Stelios Papastratos
Created on May 11, 2020
Implement ColdFluids Water/EG at different EG compositions in PRO/II (similar to DowTherm) [AVEVA on behalf of European Customer]
Currenty we can define pure components Water/EG but we cannot predict the freezing point behaviour at different EG compositions. Specific Heats based on IDEAL and Curl-Pitzer enthalpy gives reasonable results. IDEAL is predicting constant CP at temperatures below -20C. SRKM enthalpy is not predicting appropriate directionality. You can check attached excel file.
CP, Density and viscosity should be accurately predicted based on widely available experimental data, for example: : https://www.engineeringtoolbox.com/ethylene-glycol-d_146.html
If fluid temperature goes below the freezing point calculations should stop with error or if solved explicit warning should be provided.
Idea industry Other
Idea target user Process Design Engineer, Utilities engineer, Central department simulator expert
Idea business value
For the moment user is configuring table values. This is time consuming and not accurate. Quote from customer "! I suggest that modelling of water – EG mixtures is listed as an enhancement request, is a quite commonly use cooling liquid to my knowledge.
For now we would go with table values for the data required, such a density, CP and viscosity.
