Status Implemented
Products Process Design
Created on Aug 5, 2020
Calculator Enhancement
The current dialog box for Calculator in PROII is small. in some cases we have a large number of parameters in a calculator, and it is inefficient and prone to errors when we have to navigate back/forth between “Parameters”/“Results” and scroll up/down to make sure the right parameters are used in the “Procedure” section.
Idea industry Refining
Idea target user Process Design Engineer
Idea business value
When you have a large number of inputs / constants and results, being able to expand the input window will reduce chances of errors (e.g. referencing the wrong parameter in the results) and reduce time to set up (e.g. don't have to switch back and forth between parameter tab and result tab
  • Admin
    Andrew Nathan
    Nov 1, 2023
    This has been implemented in PRO/II 2024.
