Status Considered for roadmap
Created on Sep 1, 2020
Enhancement request for Relief Valve
1. Suggest to show back pressure correction factor Kb in the PRV input window.
2. Recommend allowing user to specify set pressure and allowable accumulation. This enables relief valves to cover different scenarios (single valve - 10%, multiple valves - 16%, fire - 21%, etc.). Another option which could resolve this and the above comment would be to force the inlet to be at accumulation and make the user specify set. Unit would fail and throw an error if accumulation is less than or equal to set. Regardless of approach, help documentation with the assumptions is critical.
Idea industry Refining
Idea target user Safety engineer
Idea priority 2 – Limited use to my company
Idea business value
Make it easier to specify input for PRVs and allows user to switch between different scenarios easily without running into errors.
