Status Submitted
Products Process Design
Created on Oct 28, 2019
Guard Expression evaluation against certain disallowed regions (SimCentral)
Motivation
Some mathematical expressions cannot be evaluated across the whole value range. Those expression might represent discontinous areas or physical regimes. Such expressions are usually used in empirical formulae, e.g. two-phase flow, complex phase behaviour, velocity/flow regime determination.
Idea
Consider adding a new built-in function to the SimCentral language that provies the following behaviour:
* y= IF(<GuardCondition>, <Expression To Evaluate when GuardCondition==True>, <Default Expression>)
Compared to the SELECT function, this function would evaluate the critical expression if and only if the GuardCondition evaluates to true. In any case, a default value is provided.
The expression should return (structual) derivatives (incidence) for all branches to avoid solver resets.
Workaround
Currently only an external function DLL could provide the desired behaviour, which requires a compiler and a user proficient with programming executable numeric code.
Idea industry Polymers
Idea target user Central department simulator expert
Idea business value
Extending the modeling language is a core requirement for increased adoption of the software, as it allows expert users to modify the software according to their needs. This is a very general feature that could enable a lot of applications for detailed design and simulation of process equipment.
