Status Submitted
Products Process Design
Created on Oct 5, 2020
Make more parameters of the Relief Valve unit available for the CALCULATOR unit in PRO/II
The only Relief Valve unit parameter currently available to the Calculator is "Back Pressure". As a minimum, it should be possible to select "Calculated Valve Area" as a parameter and, possibly other values calculated by the RV (e.g. relieving T, P, critical flow T,P, etc.). The valve area is especially important, since having this parameter will enable automatic calculation of standard RV sizes from within the calculator, along with other, potentially useful calculations such as net area (i.e. area/mass flow) .
Idea industry O&G, Gas Processing, Refining, Petrochemicals, Other
Idea target user Process Design Engineer, Safety engineer
Idea business value
This enhancement would save an engineer's time by enabling them to include calculations within the software. It also means there is a smaller chance of transposition errors, which could occur when copying results out of PRO/II.
