Status Submitted
Products Process Design
Created on Oct 29, 2019
Add user-defined functions/algorithms as modeling objects in the model editor (SimCentral)
Motivation:
Many real-world engineering problems require algorithms to be solved effectively, and cannot be expressed in purely algebraic form. These algorithms should be part of the SimCentral modeling language, as they are also supported in most other modeling languages (Modelica, competitor software). The theory of embedding algorithms in simulators are discussed in many publicly available articles.
Workaround:
Currently the only chance to implemenent an algorithm would be with the help of the external function interface, which requires a compiler and programming know how.
Minimal Example:
I would imagine that user-defined algorithms become part of the model editor. When added to the model, the user needs to provide the calculation steps in a simple scripting language
function Z = MyAlgorithm(T,p, x):
 if(T<298)
 Z= 0
else if(T>368):
Z=1
else:
Z=0.5
end
return Z
The derivatives of the result values would have to be calculated using automatic differentiation rules for algorithms, which are well defined in the scientific literature.
The Algorithms would be able to work with all the variables and parameters defined in the model, and would be adressed by adding an equation of the following form to the model:
EQ1: Z=MyAlgorithm(T,p,x)
Idea industry Polymers
Idea target user Central department simulator expert
Idea business value
Custom Algorithms enable the simulator expert to embed any kind of logic into the flowsheet calculation. This increases the applicability of the tool as more and more real-world discrete/continuous problems can now be formulated adequately.
