Status Not considered
Created on Oct 27, 2020
Make Collection Set option (data collection speed) in Trend a Configuration Parameter
Currently, each variable in Trend has its own Collection Set parameter (Very Fast, Fast, Medium, or Slow). Suggest making this a "Global" parameter, set in the Configuration section, with a column in the Table to override to selection from Configuration. if needed
Usually all variables in a Trend will be displayed in the same sampling rate (e.g., Fast or Medium), as mixing sampling intervals will cause confusion. The proposed change will also be more ergonomic, instead of changing the selections for up to 10 variables in the Trend table, it only needs one change in the Configuration section.
Idea industry O&G, Gas Processing, Refining, Petrochemicals, Power, Polymers
Idea target user Process Design Engineer, OTS Instructor, Simulation model writer
Idea business value
The change will make using the Trend in Dynsim more efficient (faster when switching sampling rate), with high ergonomic benefits (up to 10 times drop-down list selections and clicks).
