Status Implemented
Products Process Design
Created by Stelios Papastratos
Created on Mar 4, 2021
Add a function equivalent to XPROPX common block for classic UAS for modular UAUOP for fixed component data [PRO/II - TOTAL]
  • And finally, how can we have access to components properties in a modular UAS? I must confess that I did not check if it is mentioned in the documentation of the version 2020. – For classic UAS, we can get all the properties from CMN. However, in modular UAUOP all the information is passed through UAUOP object. In these objects, only the information required to run the unit operation is passed like feed and product data etc. Individual component data is not passed through this.
  • XPROPX and DPROPX are documented on p301 of the UAS manual.
The XPROPX common only works for the old UAS functionality, there is no equivalent for modular UAUOP. If needed, this needs to be logged as an enhancement to pass this data, so that would need to go in AHA.
Idea industry O&G
Idea target user Simulation model writer
Idea business value
  • UAS is actively used within the specific customer
  • Modular UAS is the path forward for UAS models
  • Modular UAS should allow access to fixed component properties in a similar manner as it is currently done for classic UAS.
  • Admin
    Andrew Nathan
    Nov 2, 2023
    We can show example of how to use XPROPX IN UAUOP with PRO/II 2021 files.
