Status Submitted
Products Process Design
Created on Oct 30, 2019
CSS-like stylesheets for formatting flowsheet icons (SimCentral)
Motivation:
The SimCentral canvas is already very flexible. Formatting all the streams and icons in such a way that they represent the PFD requires much manual effort though. With the help of of Cascading Style Sheets or WPF-like Styles it would be possible to pre-define a look and feel for the unit operation symbols that align with the corporate identity or the requirements of the engineering department. When using styles, it would be possible to quickly change the look from "work mode" to "presentation mode", including simplified icons and reduced level of detail.
It would be important to assign styles based on model class, instance names (even partial names or patterns, e.g. "HEX***" or custom assigned classes). It must be possible to address line and fill colors, line styles, text formatting (size, weight, color, effects).
Workaround:
It is possible to perform all formatting options by hand.
Idea industry Polymers
Idea target user Process Design Engineer
Idea priority 2 – Limited use to my company
Idea business value
Reducing the gap between process simulation flowsheets and PFD (process flow diagrams) is a big factor in improving communication between departments, as the PFD is the universally accepted language for describing flowsheet topology. If the simulation file looks "just like the PFD", a much larger audience will be enabled to understand and work with the files.
