Status Not considered
Products Process Design
Created on Nov 5, 2019
Provide more process detail to the combustion section of a fire heater (McDermott – Willem van Ramshorst)
Problem: As a user a detailed flue gas composition is essential.
The main objection regarding the current “fired heater” module is that it has no relation to the normal work we process engineers, being the majority share of simulation users, do. That the module automatically converts fuel (HCs) to flue (CO2, H2O) and calculate the adiabatic flame temperature is great but where are the air properties? Air quality (e.g. relative humidity) is an integral part of these calculations and the flue gas composition (outside the tubes) is as critical as the composition of the process (inside the tubes). The input requirements are all way too detailed (more heater mechanical related) and should be limited to a flue gas arch (bridge wall) temperature, a process X-over temperature, an access air requirement (please note that residual oxygen in flue gas, defining the excess, air is always on dry basis and not on a wet basis as you example uses), and potentially a maximum heat flux (required for area calculations). Easy modelling of the convection section and combustion air preheat must be part of the calculation module. It would be super if the module could estimate a NOx emission based on the adiabatic flame temperature but a detailed flue gas composition (even without NOX) is essential.
Modelling of an SCR bed (= deNox unit) and ID (FD?) fan power is something you could evaluate as additional functionality.
Idea industry Petrochemicals
Idea target user Process Design Engineer
Idea business value
By knowing the detailed flue gas, additional calculations for environmental purposes can be calculated.  This issue is affecting several projects per year
