Status Submitted
Products Process Design
Created by Stelios Papastratos
Created on Jul 6, 2021
Add Heat loss in simple heat exchangers / PROII, European Customer
Heat losses today normally require that you have to double all the equipment you have in your PFD which make it very complicated. This must be an easy task to improve.
You can also add a bypass stream and you can extract heat exchanger results and apply a heat loss factor to all relevant results.
But it is true that additional effort is required and will be easier to have a global simple heat exchanger user configured factor that could be overwritten in individual heat exchangers (default zero)
Idea industry O&G, Gas Processing, Refining
Idea target user Process Design Engineer, Central department simulator expert, Simulation model writer
Idea business value
It will improve accuracy of results and/or minimise effort
