Status Submitted
Products Process Design
Created by Hiromi Yorke
Created on Aug 30, 2021
[Onbehalf of Mr Makino from ENEOS Corporation] Avoidance to display as Pseudo stream when there is single outlet stream from Drum
As a flash drum is set to dew point and F2 port is connected, the stream is coloured as a pseudo stream with ver. 2020. Experienced users remember a stream from F2 port can be mixed phases when duty=0 is set, for instance. But for dew point calculation, it is actually defined for liquid.
This can be confusing, so the following enhancement is requested:
1. If only one product stream is connected to flash unit, it should not be considered as pseudo stream and should be displayed as normal stream.
2. When 2nd stream is connected, then based on flash specifications corresponding stream display will change to pseudo stream or normal stream. When multiple streams are connected, then ‘product phases’ option is also activated for user entry/reconfirmation.
Idea industry O&G, Gas Processing, Refining, Petrochemicals
Idea target user Process Design Engineer
Idea business value
There are currently 200 users in the corporation. One person can spend on this confusion for 30 min a year, which makes approximately 100 hours of time loss. In addition, about 30 users increase every year and the impact gets bigger as this feature is left.
