Status Submitted
Products Process Design
Created on Apr 13, 2022
Hcurve HTRI Interface improvement (Creating .dat file that can be registered as Fluid at once) [From JGC Mr. Fujii)
According to the current functions, the .dat file created by that Interface can only be converted into Property temperature data for one Pressure when imported into HTRI.
It is not possible to load several pressure points, so please improve so that the created .dat can create multiple Property Tables.
Idea industry O&G, Gas Processing, Petrochemicals
Idea target user Utilities engineer, Plant engineer
Idea business value
- It is assumed that the estimated radix of the annual heat exchanger Thermal Rating for JGC is about 10,000 to 20,000 (although it is quite rough...).
- It takes about 2 hours to input each set of Hot / Cold side Heat Curve data (standard pressure 3 sets, 1 set temperature 10 divisions) to HTRI.
- Assuming that the estimated radix is 20,000, a simple calculation shows 20,000 x 2hr = 40,000hr.
- If you can input 3 sets at the same time, you can input in about 1/10 of 2h.
- With the above assumptions, annual reduction of 36,000 hours
