Status Submitted
Products Process Design
Created by Stelios Papastratos
Created on May 16, 2022
Add a validation test of PRO/II ChemDist for VLLE internal condenser configuration tower [PRO/II] on behalf of European Chemical PRO/II user
Recently as a result of Support Request 960094980 a Bug 1415468 has been identified. Internal Condenser calculated vapor flow was not the same when an identical external flash calculation was performed. In other words we were getting "wrong results without warning".
The reason was bad Binary Interaction parameters due to the FILL UNIFAC or Lungy unifac fill METHOD.
Configuring the same column with an external condenser and using either ChemDist or SURE method was solving fine.
The idea here is to add a validation check at the end of the solution to test results against an external flash with same conditions of the internal ChemDist algorithm and raise a warning if results are different within a certain tolerance
Idea industry Other
Idea target user Process Design Engineer
Idea business value
"Wrong Results without Warning" should not be produced. In general an internal condenser configuration is easier to solve than an external configuration. User end of validating results by adding an external flash calculation to validate results. If results are different that creates confusion and reduce confidence with simulation results
