Status Considered for roadmap
Products Process Design
Created by Naoko Harada
Created on Jan 24, 2023
[Onbehalf of Mr Makino from ENEOS Corporation] [PRO/II Column Unit] Enable phase selection for the reflux ratio calculation
In PRO/II Column unit, reflux ratio is calculated as below when vapor product and decant water exist, in such case as "partial condenser" and "decant water option" is selected.
Reflux Ratio=Reflux÷(Vapor produt+Liquid Distillate+Decant water)
However, in engineer's actual work, calculation of "Refux Ratio=Reflux÷Liquid Distillate" is most commonly required. Currently there is no selection for user to specify calculation phase.
It is desired to add new function to select phase of reflux ratio calculation.
Idea industry O&G, Gas Processing, Refining
Idea target user Process Design Engineer, Central department simulator expert, Plant engineer
Idea business value
Engineer’s MH will be reduced by avoiding rework related to reflux ratio calculation, approximately 10MH.
  • Admin
    Andrew Nathan
    Dec 7, 2023
    We are considering to implement this in PRO/II Version 2025. I will send an update once this feature is ready in this particular PRO/II version.
