Status Submitted
Products Process Design
Created on Jun 30, 2023
Enable automatic update of PRO/II CapEx data from sizing calculations during runtime.
* This applies predominantly to Simple HX and Column results *
A prerequisite of the CapEx calculations is to provide information such as column diameter, tray spacing, HX area, etc. However, these values can also be calculated by PRO/II. It would be useful to have the choice that any calculated values that affect the CapEx calculations would over-write the pre-defined values. In this way, for example, if column dimensions change due to increased flowrates, the change is automatically managed by the CapEx calculations.
Idea industry All
Idea target user Process Design Engineer
Idea business value
This feature would significantly streamline the process of assessing alternative designs, because at present any changes to calculated equipment sizes must be updated manually in the CapEx calculations. Automating that process would enable multiple options to be assessed in a single run, knowing that any size changes are being taken into account in the CapEx figures.
