The heat of mixing for alcohol + water system is quite complex even though if alcohol is quite popular alcohol like methanol and ethanol. The change in mixing enthalpy behavior between exothermic and endothermic is determined by the balance between the kinetic energy and intermolecular interactions due to changes in temperature, pressure (intermolecular distance), and composition since alcohol molecule is consisted of hydrophobic part and hydrophilic part.
Therefore, the current framework of PRO/II and TDM have the following items as further enhancements.
1) Even though the liquid activity coefficient (LACT) model which is specified as K value calculation mode is applied for calculation of heat of mixing, PRO/II cannot keep two different binary parameter sets (namely, for instance, one is tuned for VLE and the other is tuned for heat of mixing). Therefore, actually, it is not possible to apply the tuned binary parameter set for calculation of heat of mixing on multi-phase flow sheet simulation.
2) The existing TDM which is an utility tool for parameter regression cannot allow simultaneous regression between phase equilibria (VLE & LLE) and heat of mixing.
As conclusion of my study, the following items are suggestions to further enhancements of PRO/II.
(a) Enhancements of the existing Redlich-Kister
Even though Redlich-Kister is a polynomial equation, it is a simple and flexible fitting model. Therefore, as a further extension, it is easy to introduce temperature dependency parameters to each RK binary parameter. As temperature dependency equation, simple polynomial equation (recommended up to quartic equation, but usually cubic equation is enough) is recommended.
(b) Enhancements of the existing framework for user’s choice of LACT model for heat of mixing
As countermeasure, several modification plans can be suggested. But, as simplest solution, I suggest PRO/II to accept unique user choice of liquid activity model with tuned binary parameter sets for model of heat of mixing. This unique user choice shall be independent from choice of thermodynamic model for K value.
(c) Enhancements of TDM
TDM shall accept VLE (and/or LLE) and heat of mixing simultaneously as experimental data set for correlation of LACT model. However, if we focus on alcohol + Water system, my impression is that simultaneous regression between VLE (and/or LLE) and heat of mixing is probably hopeless. However, I think that this improvement on TDM would be useful for other binary system.
This is not request, but it was my surprise that the existing TDM was easy and smart to find good binary parameter set of NRTL for heat of mixing of Ethanol + Water system. Consequently, I had a quite good impression to TDM
As detail testing results, refer the attached file.
