Status Submitted
Products Process Design
Created by Naoko Harada
Created on Sep 17, 2024
[On behalf of Mr. Makino from ENEOS Corporation] [PRO/II] Request to review default thermodynamic setting of CAPE-OPEN unit
This request is related to the case where using CAPE-OPEN to link with HTRI.
Thermodynamic setting of CAPE-OPEN unit itself is always same as input stream. It can’t be changeable by user.
On the other hand, thermodynamic setting of CAPE-OPEN unit output stream can be selected by user and its default setting is same as the “default system” which is defined in the global thermodynamic data setting window.
When “default system” is applied for CAPE-OPEN input stream thermodynamic setting, CAPE-OPEN unit itself and as well as its output stream are calculated with “default system”.
When other than “default system” is applied for CAPE-OPEN input stream thermodynamic setting, CAPE-OPEN unit itself is calculated with the same thermodynamic system as the inlet stream. However, CAPE-OPEN output stream is calculated with “default system”. Thus CAPE-OPEN unit output stream is re-flashed with “default system” and result in discrepancy of HTRI calculation results and CAPE-OPEN output stream. To avoid the inconsistency, user need to call up "CAPE-OPEN Settings" from the right-click menu of CAPE-OPEN unit and change thermodynamic setting to be consistent with CAPE-OPEN unit itself.
Basically, user expect to use same thermodynamic system for CAPE-OPEN unit itself and its output stream.
The current default settings may result in re-flash calculations occurring unintentionally by the user.
Therefore thermodynamic setting for CAPE-OPEN output stream should match with CAPE-OPEN unit itself as of the CAPE-OPEN unit default setting.
Idea industry O&G, Gas Processing, Refining, Petrochemicals
Idea target user Plant engineer
Idea business value
Improve engineer’s work efficiency and engineer’s MH will be reduced.
