Status Received & categorized
Products Thermodynamics
Created by Hiromi Yorke
Created on Nov 12, 2024
MOL file input in TDM\Property Synthesis for predicting thermodynamic parameters
Current Property Synthesis allows user to input SMILES data, but not to import MOL file to draw molecular structure. MOL file export is common and reduces the operation time, in comparison to drawing on the canvas. There are online converters to SMILES, but online tools have a concern in terms of information security.
Idea industry O&G, Midstream, Gas Processing, Petrochemicals
Idea target user Process Design Engineer, Themodynamic expert
Idea business value
The MOL file import feature will reduce time to input structure data to predict thermodynamic parameters in Property Synthesis. It would be useful if MOL file can be imported with 1 click, such as right-clicking on the canvas to select the file on the PC.
    Jan 26, 2026
    As information, Property Synthesis is based on an old version of ProPred. The new versions of ProPred allow import of MOL files in addition to SMILES.
    Nov 14, 2024
    Posted by Jochen Steimel on the respective IMS page:
    Hi Team,
    @José Fonseca was right. Python already provides an extensive suite of open-source tools that we and customers can use to automate routine tasks like that.
    The following streamlit app produces an UI where the user can drag&drop a mol file, visualize the molecule (for error checking) and get the SMILES
    The user needs to have python and install the following modules via pip install ...
    • streamlit
    • streamlit_ketcher
    • numpy
    • rdkit
    import streamlit as st
    from streamlit_ketcher import st_ketcher
    import numpy as npimport rdkit
    from rdkit import Chem
    from io import StringIO
    st.title("Mol-File to SMILES")
    mol_file = st.file_uploader("Choose a MOL-File")
    if(mol_file is not None):
    bytes= mol_file.getvalue()
    text = StringIO(bytes.decode("utf-8")).read()
    smiles = st_ketcher(text)
    m = Chem.MolFromMolBlock(text)
    st.markdown(f"SMILE code: {Chem.MolToSmiles(m)}")
    The customer can start this app by typing: streamlit run <filename>.py and a browser window should pop up with the website already opened.
    One could of course rewrite the code to operate on all *.MOL files in a folder, whatever the customer requires.
