Status Submitted
Products Process Design
Created by Stelios Papastratos
Created on Dec 20, 2024
Thermosyphon Reboiler needs a better initialisation method
Recently we had a support case from a north European large PRO/II user indicating that thermosiphon reboiler will fail without supplying column initial estimates. In fact this specific column could easily solve without any column initial estimates for kettle reboiler. The general conclusion from customer about thermosyphon reboiler is that its performance is "NOT PREDICTABLE" and in general secondary support (Dave Earp) agrees with that.
From a technical point of view this model should not include any column initial estimates because many scenarios should be run and initial estimates will help for some scenarios but fail for other scenarios. Use of "Refinery" estimation method is the best to use.
Customer would expect a similar convergence performance when thermosyphon reboiler is used considering that the overall results between kettle and thermosyphon are very similar. Therefore the impact of initialisation is not well understood.
Workaround of first solving kettle, produce initial estimates and then solve for thermosyphon has not been accepted. Manually Scaling Liquid/Vapor profiles is also not accepted.
Specific PRO/II models and more information could be provided on demand.
Idea industry Petrochemicals, Other
Idea target user Process Design Engineer, Central department simulator expert
Idea business value
Because of this limitation thermosyphon reboiler is not used but for some projects it does make a difference in results especially at the bottom column area.
