Status Submitted
Products Process Design
Created by Mohamad Ibrahim
Created on Oct 29, 2025
Add double pipe heat exchanger in PRO/II
Wood PLC UK have asked to add a dedicated unit for double pipe heat exchanger. For now, we have recommended to use the rigorous heat exchanger with some modifications to mimic the double pipe heat exchanger. Client believes it is much more helpful and easier to have a dedicated unit for the double pipe HX.
Idea industry All
Idea target user Process Design Engineer
Idea priority 5 – Critical to my company
Idea business value
  • Current PRO/II exchanger options are built around TEMA shell-and-tube designs, which assume tube bundles, baffles, and multi-pass layouts.
  • Double-pipe exchangers are simpler: one inner pipe, one outer pipe, often finned, and no shell or baffles.
  • Using the shell-and-tube model forces a workaround that requires manual entry of tube counts and shell data, giving poor pressure-drop and thermal predictions for concentric geometry.
  • A dedicated double-pipe model would take inner/outer pipe dimensions directly, calculate area and pressure drop automatically, and remove the need for manual approximations—giving faster, cleaner, and more accurate results for small-duty, high-pressure services.
