Status Considered for roadmap
Products Process Design
Created by Seiya Hirohama
Created on Dec 16, 2025
[On behalf of Advisory Group] Enhance RGRESS for APS
REGRESS for APS to cover the following items:
  1. REGRESS for eNRTL parameters together with reaction equilibrium constants on Fluid Sub-model on APS without relying on external script like python which chemical engineers are not always familiar wtih.
  2. Enable users to set constraints on parameters, such like avoiding set of parameter values which predict LLE occurrence
  3. Use of plant operation data together with laboratory data at the same time
  4. Use of multiple types of data including heat of mixing and VLE/LLE at the same time to determine a set of BIPs (like SIMIDEAS-I-342 suggested for PRO/II and TDM)
  5. Enable users to change range of conditions to indicate phase diagrams to which experimental data are superimposed
  6. Use of 3+ component data together with binary data to decide BIPs
  7. Enable users to put weight for each data
Idea industry Other
Idea target user Process Design Engineer
Idea business value
For Item 1: For designing carbon capture using proprietary amines, process engineers need to tune the thermo model for making simulation match the laboratory data which are measured by the customer and are confidential
For Items 2-5: designing chemical processes needs reliable parameter values which should make simulation much the real operation
