Status Considered for future plans
Products Thermodynamics
Created on Nov 27, 2019
Extension of maximum available temperature of liquid enthalpy curve of SimSci DB
Table 1 shows survey results for maximum available temperature (Tmax) of liquid enthalpy curve of SimSci DB and Process DB for aromatic compounds. Tmax of Process DB is basically equal to critical temperature. In contrast, Tmax of SimSci Db is too low. In Table 1, I estimated vapor pressure at Tmax for each compound. The vapor pressure values at Tmax of some compounds are under vacuum conditions. The others are at just atmospheric pressure except Benzene, Toluene, p-Xylene and Cumene. The compounds selected in Table 1 are major compounds for modeling of distillation tower of production plant of variable aromatics. Basically, the operating conditions of distillation columns of aromatics plant are atmospheric pressure to 500 kPaG in general. From these points of view, the current SimSci DB is not enough for modeling of aromatics plant.
AVEVA now provides extension options of temperature range. However, AVEVA shall examine reliable liquid enthalpy curves for the above compounds and provide more reliable DB since SimSci DB is a Db originated by AVEVA themselves.
Idea industry Refining, Petrochemicals
Idea target user Process Design Engineer, Themodynamic expert
Idea business value
Reliable database is quite important foundation for simulation work.
  • Admin
    Seiya Hirohama
    Feb 4, 2021
    Updated data for m-xylene, 1,3,5-trimethylbenzen, and 1,2,4-trimethylbenzene. For other components listed in the EXCEL file, we are still looking for appropriate data.
