Status Submitted
Products Process Design
Created on Mar 16, 2026
Add additional parameters to the Unit Property Table for the Solid Gas Cyclone.
[On behalf of Dmitrii Ivanov dmitrii.ivanov@edl.poerner.de ] Add key Rating-mode results for the Solid Gas Cyclone to the Unit Property Table so users can quickly review performance without opening detailed reports. In particular, expose the cyclone’s Mode of Operation (Rating), the selected calculation methods (Efficiency: Koch and Licht, Pressure Drop: API), and the primary results such as Total Efficiency (%) and Pressure Drop (kPa). Additionally, include Particle Size Distribution (PSD) summary information for the rated component (e.g., Component 2 – CaCO3), including size range/average diameter, feed and product weight fractions, grade efficiency per PSD cut, and the overall component efficiency. This enhancement improves visibility, supports faster model validation, and simplifies comparing cyclone performance across cases.
Idea industry Gas Processing
Idea target user Process Design Engineer, Simulation model writer
Idea business value
I am adding idea as per request from dmitrii.ivanov@edl.poerner.de for this requirement. Adding Solid Gas Cyclone Rating results to the Unit Property Table provides quick, at-a-glance access to the key KPIs (Total Efficiency, Pressure Drop, selected methods, and PSD/grade efficiency by cut) without opening detailed reports. This streamlines iterative tuning and sensitivity studies, makes case-to-case comparisons easier, and reduces manual copy/paste during reviews and documentation.
    Mar 16, 2026
    This information is available in Text Reports but this request for adding it on Unit Property Table.
    Solid/Gas Cyclone
    MODE OF OPERATION: RATING
    EFFICIENCY CALCULATED BY KOCH AND LICHT METHOD.
    PRESSURE DROP CALCULATED BY AMERICAN PETROLEUM INSTITUTE METHOD.
    TOTAL EFFICIENCY, % 98.6035
    PRESSURE DROP, KPA 0.0296
    PARTICLE SIZE DISTRIBUTION
    COMPONENT 2 - CACO3
    -------- DIAMETER, MM -------- --- WT FRAC ---- --- PSD GRADE ---
    RANGE AVERAGE FEED PRODUCT EFFICIENCY ,WT%
    10.00 - 20.00 E-03 15.00 E-03 0.10000 0.61650 89.738523
    20.00 - 30.00 E-03 25.00 E-03 0.15000 0.29078 96.773358
    30.00 - 40.00 E-03 35.00 E-03 0.50000 0.09271 99.691367
    40.00 - 60.00 E-03 50.00 E-03 0.25000 0.00000 1.000E+02
                                COMPONENT EFFICIENCY     98.335540
