Status Submitted
Created on Apr 23, 2026
[On behalf of Ms. Ono from JFE Engineering corp.] [AVEVA Dynamic Simulation] Request to improve Anti-Windup control
When the PID output reaches its upper or lower limits (typically 0–100%) and remains there for a while, the deviation from the process value begins to accumulate.
This means that the integral term increases, and even if the conditions return to a state where the upper or lower limits are released, the output may not return to normal for some time due to this accumulated integral value (wind-up).
The “anti-wind-up” function is designed to prevent this.
There are several types, but a typical system resets the accumulated deviation to zero once upper or lower limits are reached.
This function is often used in actual plant control, and they request that it be incorporated into the PID unit or into a new unit in the ADS.
For details on the features, please refer to the link below.
https://www.scilab.org/pid-anti-windup-schemes
https://jp.mathworks.com/help/simulink/slref/anti-windup-control-using-a-pid-controller.html
Also attached literature from the time this feature was developed, which is available for free (Astrom-ACC89-pdf).
Idea industry Gas Processing, Midstream, O&G, Petrochemicals
Idea target user Control engineer, Plant engineer, Process Design Engineer, Safety engineer
Idea business value
This feature is included in ASPEN Plus Dynamics and ASPEN HYSYS Dynamics.
Currently, They implements it as UAM, but since it is cumbersome to manage, they would like to see it included as a standard feature in the ADS.
