Yes similar, but sequence block is not always same with block diagram. If user can specify sequence block separately with block unit, it is useful.
Please see attached video. Is this what you want to do? Move a section of the sequence from one place to another? Granted, not easy to move on a long long sequence, and that can be improved.
Please try to make convergence by define the sequence by using the attchement. The final solution may be Casebook_VCM_Plant. (But this is not so big flowsheet.)
The way this is written sounds like we can do that already. If user groups series of equipment on subflowsheets one can disable the later part of subflowsheets until the earlier part is converged, Then as the subflowshets are converged, disable the converged parts and continue with the next logical part. User can do one or many subflowsheets at a time. Regardless if sequence was set manually or by MTS, the overall sequence is remembered. If this is not enough, please provide a prz example with a detailed step by step showing the problem and the manual solution.
