Status Submitted
Products Process Design
Created by Stelios Papastratos
Created on Feb 24, 2020
Reaction with user defined heat of reaction at different reference conditions should be properly considered [PRO/II] [AVEVA on behalf of European Customer]
See also SIMDEAS-I-90:
If a user has configured a custom reference state, for one or all the reactions, the default behaviour should be to use those conditions.
I would understand if PRO/II behaved in the opposite way to be helpful: if a custom reference state has been used for one reaction, then all should use the same custom reference state, even if the user forgot to change this from default for the other reactions.
Current workaround is to convert the reference state heat of reaction via the following enthalpy balance: DHr (b) = (H2(a) - H3(a)) + DHr (a) - (H2 (b) - H3(b)
Where (a) is the reference state we have the heat of reaction data for, (b) is the PRO/II default reference state, and the ‘2’ and ‘3’ refer to the inlet and outlet streams (in-line with the PRO/II Hess Law diagram for reaction heat balance).
SR reference number: 109810503
Idea industry Other
Idea target user Process Design Engineer, Central department simulator expert, Simulation model writer
Idea business value
It is very time consuming to apply the workaround
